change height ,bust,low hip and waist circumference-sovled
xihaohuang18xihaohuang18 Posts: 2
edited May 2022 in Daz Studio Discussion
I am try to change the avator's height, bust circumference, low hip circumference,and waist circumference.
In the verison 4.16, I do can find those Label from the object property, but in 4.20 version. It seems like they changed the name(not sure), I cannot find the avator's height, bust circumference, low hip circumference,and waist circumference right now. Does anyone had same problem?
Post edited by xihaohuang18 on
  • Richard HaseltineRichard Haseltine Posts: 111,696
    As Parameters or using Measure Metrics/Figure Metrics? Do you have Figure Metrics installed?
  • What I do is load file with default avatar and action,and then retrieve the properties from avator and then change the hight, bust,low hip,waist value and then adjust the shape.
