How do I activate fit control for genesis and genesis 2 females
odinmtgodinmtg Posts: 22
Hello, i just purchased Zev0's fit control for G2F and it says its a script that needs to be activated. I use Daz ZStudio and I have no clue how to do this. I tried opening the IDE script tab and searching for it... be yea, no idea. Could someone please help me?
  • Richard HaseltineRichard Haseltine Posts: 111,677
    It should have a thumbnail in the Content Library (and probably in Smart Content) - just double-click that to run the script.
  • LindseyLindsey Posts: 2,017
    You'll find the Fit Control scripts in two places:
    Genesis>Clothing>Fit Control
    Genesis 2 Female>Clothing>Fit Control
    After applying the clothing with smoothing enabled, select Genesis or Genesis 2 Female then run the Fit Control + script for that figure.
  • odinmtgodinmtg Posts: 22
    Wow, I can't believe I didn't find that. Thank you, I appreciate your help :)
  • Nelson ThorontoNelson Thoronto Posts: 1
    Yeah, that doesn't work for me - no matter what I do, that script can't be loaded... Even when clicking on the icon (it gives me a 'file not found' error). I'm going to ask for a refund, as I believe this product may not be compatible with Daz Studio.
    I've been using it with Daz Studio. There might be a way to fix your problem?? Hopefully, because it's pretty awesome
    Glad I could help. I, like you, followed the step by step instructions and when instructed to load the Fit Control + script, I went "Huh?" .. LOL. I used DIM to locate where the scripts where installed when I didn't find them in the Scripts folder.
    This product is ONLY for DAZ Studio, since it is a DAZ Studio Script. How did you install this product?
    What version of DAZ Studio are you running, Help > About DAZ Studio will tell you the exact version number?
  • BeeMKayBeeMKay Posts: 7,019
    Did you install manually, or using DIM?
    Did you select a G1/G2 character before applying the script?
  • namffuaknamffuak Posts: 4,520
    Over in the announcement thread someone determined that this will only work in Studio 4.7 and above; it fails in 4.6 (and probably earlier). So - are you running 4.7?
    That was me, discovering that it doesn't work in D|S4.6 — the problem is the script is encrypted, which frequently locks out any D|S version earlier than the one the script was saved in. I'm waiting until 4.8 comes out of beta so I can install it and everything should work.
  • MJWMJW Posts: 540
    Have managed to get as far as the 'fit control has been transferred...' pop-up, but where do I find the morph dials etc, please? I can find what are probably the right adjustments in the CMS parameters tab, but there is not a poser style panel as shown in the product blurb:
    http://www.daz3d.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/0/1/01-fit-control-for-genesis-and-genesis-2-females-daz3d.jpg
    edited May 2015
    You will not find them in the CMS tab...
    Select your clothing piece, go to the Parameter's tab and select Actor. There, you will find a sub-directory "Fit To".
    Post edited by BeeMKay on
  • GnotMeGnotMe Posts: 131
    Does not work.  I follow the instructions, click on the + Icon, there is a delay but there is no confirmation. When I check for Fit Control under the Parameters, with Clothing item selected, there is no Actor, nor Fit Control.
    I'm using DStudio 4.8, everything else seems to work, but not Fit Control.
