Shut Down & Start Up Problem
PatroklosPatroklos Posts: 533
I am using the beta version, when I shut down, often DazStudio won't start up again unless I reboot my computer.
Can I cure this by changing a setting?
  • Richard HaseltineRichard Haseltine Posts: 112,059
    What are you system specifications?
  • PatroklosPatroklos Posts: 533
    I have an iMac (Retina 5K, 27-inch, Late 2014) 3.5 GHz Intel Core i5, 32 GB 1600 MHz DDR3, AMD Radeon R9 M290X 2048 MB, Yosemite10.10.3 (14D136)
    I can't recall how to get a list of running tasks on a Mac, but make sure that DS has actually closed. If it hasn't there may be a problem with a plug-in that could be locking it.
  • Cris PalominoCris Palomino Posts: 13,053
    edited May 2015
    You can go to your Utilities folder and run Activity Monitor.
    https://support.apple.com/en-us/HT201464
    Post edited by Cris Palomino on
    Yes, there is a problem here,Daz is using 99% of CPU the whole time!
    Does that happen if you just load DS and immediately quit? If not, how about loading DS, creating a primitive, and quitting? Then load, create primitive, render and quit?
    It is showing 370% cpu running, 0% when I quit, even after just d/l an update.
    Should I uninstall & reinstall, or something else?
    OK, I uninstalled and reinstalled, still the same!
    Switched off real time protection antivirus, still the same problem.
    edited May 2015
    This morning, after a night with Daz running, but nothing loaded, there was no problem, but loaded one item and 370% cpu again. (I dont understand 370% cpu!)
    Post edited by Patroklos on
    So does it stay in the task list after you quit or not? I'm a little confused by the figures you give (and I don't know what 370% CPU could mean - are you sure it isn't counting each core as 100%, if you have a four core CPU that would be all but a bit of all four cores).
    It goes from task list after quit.
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    edited May 2015
    100% is per core, 400% is four cores at 100% each
    Post edited by Design Anvil - Razor42 on
    I guess that makes sense, but no progress with the original problem.
  • TotteTotte Posts: 15,298
    When you quit DAZ Studio, does it take a while for it to quit? I know it sometimes takes while for DS to clean-up memory usage, but this has been improved since 4.6 (where it could take 30 minutes when you quit after you had a huge scene loaded).
    When you try to start it again, what does actually happen?
    Its quite quick, normal.
    Since last here I have reformatted my hard drive and restored it because of other problems, but Daz3d still the same.
