GOZ from Zbrush to DAZ not working
Hey,
I can send character from Daz to Zbrush, then I do really a really simple sculpt and the problem is that I'm not able to send the sculpt back to Daz with GoZ. The only info from Zbrush that I got is "file saved to disk sucessfully".
Daz doesn't seem to receive any info back, no pop-up message about back import.
I tried to reinstall both Zbrush and Daz and filepath from Zbrush to Daz seems correct
I have Zbrush 2022.05 and DAZ Studio 4.2 PRO
I work on a Mac
Could you please help?
438 x 262 - 61K
1670 x 570 - 140K
  • Richard HaseltineRichard Haseltine Posts: 111,363
    "Export at Current Resolutiion" will send the subdivided mesha cross, if it is a SubD model not at Base resolution. Morphs have to be made on the base resolution mesh (you can add detail via normal maps of displacement - ZBrush will let you divide the mesh, sculpt, and bake to one of those map typse)
  • Hey Richard, the model is at base resolution:/
    after several reinstalls of both Zbrush and DAZ I keep getting this error report. If that's any help
    -------------------------------------Translated Report (Full Report Below)-------------------------------------Process:               GoZBrushToDAZStudio [5625]Path:                  /Users/Shared/*/GoZBrushToDAZStudio.app/Contents/MacOS/GoZBrushToDAZStudioIdentifier:            com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0Version:               1.0 (1)Code Type:             X86-64 (Translated)Parent Process:        launchd [1]User ID:               501Date/Time:             2022-05-06 12:16:26.8236 +0300OS Version:            macOS 12.3.1 (21E258)Report Version:        12Anonymous UUID:        EA51D608-96F6-ACD2-E21B-091101700EB7Sleep/Wake UUID:       353AB0CB-3812-4F08-AE73-C78538E3794CTime Awake Since Boot: 81000 secondsTime Since Wake:       9453 secondsSystem Integrity Protection: enabledCrashed Thread:        0Exception Type:        EXC_CRASH (SIGABRT)Exception Codes:       0x0000000000000000, 0x0000000000000000Exception Note:        EXC_CORPSE_NOTIFYTermination Reason:    Namespace DYLD, Code 1 Library missingLibrary not loaded: @rpath/libdzcore.dylibReferenced from: /Users/Shared/*/GoZBrushToDAZStudio.app/Contents/MacOS/GoZBrushToDAZStudioReason: tried: '/Users/Shared/Pixologic/GoZApps/DAZStudio64/GoZBrushToDAZStudio.app/Contents/MacOS/../Frameworks/libdzcore.dylib' (no such file), '/Users/Shared/Pixologic/GoZApps/DAZStudio64/GoZBrushToDAZStudio.app/Contents/MacOS/../Frameworks/libdzcore.dylib' (no such file), '/usr/local/lib/libdzcore.dylib' (no such file), '/usr/lib/libdzcore.dylib' (no such file)(terminated at launch; ignore backtrace)Application Specific Information:Library not loaded: @rpath/libdzcore.dylibReferenced from: /Users/Shared/Pixologic/GoZApps/DAZStudio64/GoZBrushToDAZStudio.app/Contents/MacOS/GoZBrushToDAZStudioReason: tried: '/Users/Shared/Pixologic/GoZApps/DAZStudio64/GoZBrushToDAZStudio.app/Contents/MacOS/../Frameworks/libdzcore.dylib' (no such file), '/Users/Shared/Pixologic/GoZApps/DAZStudio64/GoZBrushToDAZStudio.app/Contents/MacOS/../Frameworks/libdzcore.dylib' (no such file), '/usr/local/lib/libdzcore.dylib' (no such file), '/usr/lib/libdzcore.dylib' (no such file)Thread 0 Crashed:0   Rosetta Runtime Routines	       0x100022940 ???1   <translation info unavailable>	       0x100063694 ???2   dyld                          	       0x2000c3212 abort_with_payload_wrapper_internal + 803   dyld                          	       0x2000c3244 abort_with_payload + 94   dyld                          	       0x20007176f dyld4::halt(char const*) + 3755   dyld                          	       0x20006d5a5 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 39956   dyld                          	       0x20006c4d4 start + 388Thread 1:: com.apple.rosetta.exceptionserver0   runtime                       	    0x7ff7ffca39a4 0x7ff7ffc9f000 + 188521   runtime                       	    0x7ff7ffcb1738 0x7ff7ffc9f000 + 755762   runtime                       	    0x7ff7ffcb2ed0 0x7ff7ffc9f000 + 81616Thread 0 crashed with ARM Thread State (64-bit):    x0: 0x0000000000000006   x1: 0x0000000000000001   x2: 0x000000030411d950   x3: 0x0000000000000092    x4: 0x000000030411d550   x5: 0x0000000000000000   x6: 0x000000030411d540   x7: 0x0000002000069d87    x8: 0x000000030411d550   x9: 0x0000000000000000  x10: 0x0000000000000092  x11: 0x000000030411d550   x12: 0x0000000000000092  x13: 0x000000030411d950  x14: 0x0000000000000001  x15: 0x0000000000000006   x16: 0x0000000000000209  x17: 0x0000000000000000  x18: 0x800000010808bb70  x19: 0x0000000100018000   x20: 0x00000000000007ff  x21: 0x0000000108090fa0  x22: 0xffffffffffffffff  x23: 0x0000000100022914   x24: 0x00000002000c3212  x25: 0x00000001000221f4  x26: 0x000000010005bcc8  x27: 0x0000000000000000   x28: 0x00000002000ad0de   fp: 0x000000002c000000   lr: 0x0000000100063694    sp: 0x000000010808bb70   pc: 0x0000000100022940 cpsr: 0x80001000   far: 0x0000000100063000  esr: 0x56000080  Address size faultBinary Images:               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???       0x200067000 -        0x2000d2fff dyld (*) <dd9e80de-fb3b-349b-96a4-46874ad34d11> /usr/lib/dyld    0x7ff7ffc9f000 -     0x7ff7ffccefff runtime (*) <24497be3-a1b4-360a-b90e-cde9ce78a93b> /usr/libexec/rosetta/runtimeExternal Modification Summary:  Calls made by other processes targeting this process:    task_for_pid: 0    thread_create: 0    thread_set_state: 0  Calls made by this process:    task_for_pid: 0    thread_create: 0    thread_set_state: 0  Calls made by all processes on this machine:    task_for_pid: 0    thread_create: 0    thread_set_state: 0VM Region Summary:ReadOnly portion of Libraries: Total=1240K resident=0K(0%) swapped_out_or_unallocated=1240K(100%)Writable regions: Total=155.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=155.2M(100%)                                VIRTUAL   REGION REGION TYPE                        SIZE    COUNT (non-coalesced) ===========                     =======  ======= Rosetta Arena                     4096K        2 Rosetta Generic                    760K      187 Rosetta IndirectBranch              32K        1 Rosetta JIT                      128.0M        1 Rosetta Return Stack                20K        2 Rosetta Thread Context              20K        2 Stack                             8176K        1 Stack Guard                       56.0M        1 VM_ALLOCATE                       13.3M        5 VM_ALLOCATE (reserved)               4K        1         reserved VM address space (unallocated)__DATA                             116K        6 __DATA_CONST                        80K        1 __LINKEDIT                         284K        7 __TEXT                             988K        4 dyld private memory               1024K        1 mapped file                        6.0G       28 ===========                     =======  ======= TOTAL                              6.3G      250 TOTAL, minus reserved VM space     6.3G      250 -----------Full Report-----------{"app_name":"GoZBrushToDAZStudio","timestamp":"2022-05-06 12:16:26.00 +0300","app_version":"1.0","slice_uuid":"ce9fb886-6355-c1cb-3b54-919376b63f4a","build_version":"1","platform":1,"bundleID":"com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.3.1 (21E258)","incident_id":"70EA58CA-2C52-47F4-BB1D-9C6A617452F4","name":"GoZBrushToDAZStudio"}{  "uptime" : 81000,  "procLaunch" : "2022-05-06 12:16:26.4285 +0300",  "procRole" : "Background",  "version" : 2,  "userID" : 501,  "deployVersion" : 210,  "modelCode" : "MacBookPro18,2",  "procStartAbsTime" : 1959037714544,  "coalitionID" : 6099,  "osVersion" : {    "train" : "macOS 12.3.1",    "build" : "21E258",    "releaseType" : "User"  },  "captureTime" : "2022-05-06 12:16:26.8236 +0300",  "incident" : "70EA58CA-2C52-47F4-BB1D-9C6A617452F4",  "bug_type" : "309",  "pid" : 5625,  "procExitAbsTime" : 1959047174707,  "translated" : true,  "cpuType" : "X86-64",  "procName" : "GoZBrushToDAZStudio",  "procPath" : "\/Users\/Shared\/*\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/GoZBrushToDAZStudio",  "bundleInfo" : {"CFBundleShortVersionString":"1.0","CFBundleVersion":"1","CFBundleIdentifier":"com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0"},  "storeInfo" : {"deviceIdentifierForVendor":"9530295D-9067-59A3-8B97-03809C7225F9","thirdParty":true},  "parentProc" : "launchd",  "parentPid" : 1,  "coalitionName" : "com.daz3d.carrara.GoZBrushToDAZStudio.macho.1.0.0.0",  "crashReporterKey" : "EA51D608-96F6-ACD2-E21B-091101700EB7",  "wakeTime" : 9453,  "sleepWakeUUID" : "353AB0CB-3812-4F08-AE73-C78538E3794C",  "sip" : "enabled",  "isCorpse" : 1,  "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},  "termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: @rpath\/libdzcore.dylib","Referenced from: \/Users\/Shared\/*\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/GoZBrushToDAZStudio","Reason: tried: '\/Users\/Shared\/Pixologic\/GoZApps\/DAZStudio64\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/..\/Frameworks\/libdzcore.dylib' (no such file), '\/Users\/Shared\/Pixologic\/GoZApps\/DAZStudio64\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/..\/Frameworks\/libdzcore.dylib' (no such file), '\/usr\/local\/lib\/libdzcore.dylib' (no such file), '\/usr\/lib\/libdzcore.dylib' (no such file)"]},  "asi" : {"dyld":["Library not loaded: @rpath\/libdzcore.dylib","Referenced from: \/Users\/Shared\/Pixologic\/GoZApps\/DAZStudio64\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/GoZBrushToDAZStudio","Reason: tried: '\/Users\/Shared\/Pixologic\/GoZApps\/DAZStudio64\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/..\/Frameworks\/libdzcore.dylib' (no such file), '\/Users\/Shared\/Pixologic\/GoZApps\/DAZStudio64\/GoZBrushToDAZStudio.app\/Contents\/MacOS\/..\/Frameworks\/libdzcore.dylib' (no such file), '\/usr\/local\/lib\/libdzcore.dylib' (no such file), '\/usr\/lib\/libdzcore.dylib' (no such file)"]},  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},  "faultingThread" : 0,  "threads" : [{"triggered":true,"id":704272,"threadState":{"x":[{"value":6},{"value":1},{"value":12953180496},{"value":146},{"value":12953179472},{"value":0},{"value":12953179456},{"value":137439387015},{"value":12953179472},{"value":0},{"value":146},{"value":12953179472},{"value":146},{"value":12953180496},{"value":1},{"value":6},{"value":521},{"value":0},{"value":9223372041284533104},{"value":4295065600},{"value":2047},{"value":4429778848},{"value":18446744073709551615},{"value":4295108884},{"value":8590733842,"symbolLocation":80,"symbol":"abort_with_payload_wrapper_internal"},{"value":4295107060},{"value":4295343304},{"value":0},{"value":8590643422,"symbolLocation":10,"symbol":"__abort_with_payload"}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4295374484},"cpsr":{"value":2147487744},"fp":{"value":738197504},"sp":{"value":4429757296},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":4295108928,"matchesCrashFrame":1},"far":{"value":4295372800}},"frames":[{"imageOffset":4295108928,"region":"Rosetta Runtime Routines","symbolLocation":10560,"imageIndex":0},{"imageOffset":4295374484,"region":"<translation info unavailable>","imageIndex":0},{"imageOffset":377362,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":80,"imageIndex":1},{"imageOffset":377412,"symbol":"abort_with_payload","symbolLocation":9,"imageIndex":1},{"imageOffset":42863,"symbol":"dyld4::halt(char const*)","symbolLocation":375,"imageIndex":1},{"imageOffset":26021,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":3995,"imageIndex":1},{"imageOffset":21716,"symbol":"start","symbolLocation":388,"imageIndex":1}]},{"id":704316,"name":"com.apple.rosetta.exceptionserver","frames":[{"imageOffset":18852,"imageIndex":2},{"imageOffset":75576,"imageIndex":2},{"imageOffset":81616,"imageIndex":2}]}],  "usedImages" : [  {    "size" : 0,    "source" : "A",    "base" : 0,    "uuid" : "00000000-0000-0000-0000-000000000000"  },  {    "source" : "P",    "arch" : "x86_64",    "base" : 8590356480,    "size" : 442368,    "uuid" : "dd9e80de-fb3b-349b-96a4-46874ad34d11",    "path" : "\/usr\/lib\/dyld",    "name" : "dyld"  },  {    "source" : "P",    "arch" : "arm64",    "base" : 140703125073920,    "size" : 196608,    "uuid" : "24497be3-a1b4-360a-b90e-cde9ce78a93b",    "path" : "\/usr\/libexec\/rosetta\/runtime",    "name" : "runtime"  }],  "sharedCache" : {  "base" : 140703181881344,  "size" : 15226814464,  "uuid" : "a1c5d735-ceb0-350d-9729-bb0e9be86d75"},  "vmSummary" : "ReadOnly portion of Libraries: Total=1240K resident=0K(0%) swapped_out_or_unallocated=1240K(100%)\nWritable regions: Total=155.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=155.2M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nRosetta Arena                     4096K        2 \nRosetta Generic                    760K      187 \nRosetta IndirectBranch              32K        1 \nRosetta JIT                      128.0M        1 \nRosetta Return Stack                20K        2 \nRosetta Thread Context              20K        2 \nStack                             8176K        1 \nStack Guard                       56.0M        1 \nVM_ALLOCATE                       13.3M        5 \nVM_ALLOCATE (reserved)               4K        1         reserved VM address space (unallocated)\n__DATA                             116K        6 \n__DATA_CONST                        80K        1 \n__LINKEDIT                         284K        7 \n__TEXT                             988K        4 \ndyld private memory               1024K        1 \nmapped file                        6.0G       28 \n===========                     =======  ======= \nTOTAL                              6.3G      250 \nTOTAL, minus reserved VM space     6.3G      250 \n",  "legacyInfo" : {  "threadTriggered" : {  }},  "trialInfo" : {  "rollouts" : [    {      "rolloutId" : "6112dda2fc54bc3389840642",      "factorPackIds" : {        "SIRI_DICTATION_ASSETS" : "6254a7bdc34a1e77c8f0765f"      },      "deploymentId" : 240000115    },    {      "rolloutId" : "607844aa04477260f58a8077",      "factorPackIds" : {        "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"      },      "deploymentId" : 240000066    }  ],  "experiments" : [  ]}}Model: MacBookPro18,2, BootROM 7459.101.3, proc 10:8:2 processors, 32 GB, SMC Graphics: Apple M1 Max, Apple M1 Max, Built-InDisplay: Cintiq Pro 16, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, OnlineDisplay: Color LCD, 3456 x 2234 Retina, MirrorOff, OnlineMemory Module: LPDDR5AirPort: Wi-Fi, wl0: Feb  8 2022 01:51:44 version 20.90.39.0.8.7.114 FWID 01-510a2aeeBluetooth: Version (null), 0 services, 0 devices, 0 incoming serial portsNetwork Service: Wi-Fi, AirPort, en0USB Device: USB31BusUSB Device: USB31BusUSB Device: hub_deviceUSB Device: hub_deviceUSB Device: Single RS232-HSUSB Device: USB3 ReaderUSB Device: Cintiq Pro 16 TouchUSB Device: Cintiq Pro 16USB Device: USB31BusThunderbolt Bus: MacBook Pro, Apple Inc.Thunderbolt Bus: MacBook Pro, Apple Inc.Thunderbolt Bus: MacBook Pro, Apple Inc.
