VA2022: Freebie Coffee Mug (Daz Prop + OBJ)
valzheimervalzheimer Posts: 519
edited May 2022 in Freebies
Freebie coffee mug prop created in Blender and rigged for Daz Studio with Iray material presets. Includes one rigged coffee mug prop file with bones separated for liquid and the mug (general weightmapping), 10 materials for the mug with 3 hand-drawn overlays, 5 materials for the liquids and 2 utility poses/wearables for loading mug in left and right hand for Genesis 8/8.1 Female.
Two OBJ files, low and high resolution are also included. Hope you like :)
Download available at my website (via Gumroad): https://www.valzheimer.info/2022/04/va2022-freebie-coffee-mug-daz-studio.html
*HOW TO DOWNLOAD: Hitting the "DOWNLOAD" button will prompt a Gumroad popup window. At the bottom there is a field for a price (it can be $0, you have to type the number in) then click "I want this". If you don't have a Gumroad account it will take you to make one (it's free to make). I don't host files at other services (sorry).
WHAT'S INCLUDED:
DAZ STUDIO FILES:
  • 1 Coffee Mug Prop (.DUF)
    • 10 materials for the coffee mug
      • Coffee Mug Black
      • Coffee Mug Blue
      • Coffee Mug Brown
      • Coffee Mug Green
      • Coffee Mug Grey
      • Coffee Mug Pink
      • Coffee Mug Purple
      • Coffee Mug Red
      • Coffee Mug White
      • Coffee Mug Yellow
    • 3 overlays for the coffee mug
      • Overlay Coffee
      • Overlay Leaves
      • Overlay Sunshine
    • 5 materials for the liquid
      • Liquid Coffee
      • Liquid Tea Black
      • Liquid Tea Green
      • Liquid Tea Red
      • Liquid Tea yellow
    • 7 morphs for the liquid
      • Liquid Hide/Show (On/Off)
      • Liquid Less
      • Liquid Ripples
      • Liquid Ripples Left
      • Liquid Ripples Right
      • Liquid Ripples Left/Right
      • Liquid Sway Left/Right
  •  2 wearable presets for loading coffee mug in left and right hand (.DUF)
  • 1 high resolution OBJ file and 1 low resolution OBJ file (OBJ)
HOW TO INSTALL DAZ STUDIO FILE:
Unzip contents of  VA2022_vaCoffeeMugDazStudio.zip into your base Content/My Library folder. You will find the Coffee Mug and all presets under Props>valzheimer>Coffee Mug.
Tip: Daz file is saved with general weightmapping and has separate bones for mug and liquid to make it easier to rotate/move the liquid separately to mimic real life behavior. In case where the liquid may protrude the mug and cause artifacts while combining morphs you can use the bone controls to scale/move the liquid appropriately.
Tip 2: Daz Studio Prop is saved and will automatically load with High Resolution and SubD level 2. To change this settings refer to Parameters Tab > Mesh Resolution.
This package was made in Daz Studio 4.20 intended for Iray render engine and hasn't been tested in earlier versions of Daz, 3Delight or Poser application. However materials will load in 3Delight, but may require adjustments for proper look.
OBJ files: Two OBJ files with MTL and image files are packaged separately in VA2022_vaCoffeeMugOBJ.zip file for use in external applications. These files don't load with textures or diffuse colors applied.
Have fun and happy rendering!
2451 x 3000 - 4M
641 x 764 - 271K
Post edited by valzheimer on
  • DaventakiDaventaki Posts: 1,624
    Thank you!
  • HylasHylas Posts: 5,345
    Very cool, thank you!
  • BronzeDragonBronzeDragon Posts: 381
    Looks nice, but no thanks - requires personal information.
    Your name ['cause it's better than hay you] and email address [like how else do you expect to get a receipt and have it available in indefinitely for downloading?]
    Thank you valzheimer smiley
  • valzheimervalzheimer Posts: 519
    I always come across a couple of people saying they're reluctant about registering at Gumroad and I can respect that. Main reason I upload there is to keep track of the dates when things got downloaded and customers (this mainly because I've had some bad experiences in the past) and it gives an option for people to chip in willingly if they wish to do so without having to charge the whole thing (price can be whatever you set it to be). That said I've never had a single issue with Gumroad and privacy, I've made quiet a few pennies there overtime and I have to say they've treated me well as their customer, and yes it offers great support and access to everything you've ever checked out of your cart, so that's a huge bonus. It's a freebie out there to be taken, those who don't want it aren't forced to get it :)
    You're welcome everyone <3
    PS: For a short time after the upload there's been an issue with flipped normals on the mug (entirelly my own overlook), this was corrected and files were reuploaded shortly after. If this happens and causes an issue (thought it shouldn't), just redownload the file.
    Cheers,
    V.
  • Faeryl WomynFaeryl Womyn Posts: 3,784
    Thanks for the new freebies, love your stuff, always so right on the spot for what's needed.
  • pericolopericolo Posts: 295
    I love them! Thank you!!
  • xmasrosexmasrose Posts: 1,409
    Thank you, what a great gift!
