Dynamic lingerie v6 problem in 4.8 - help!
nickalaman
If anyone had the dynamic v6 lingerie can you see if it work in studio 4.8. I seam tho be having problems. The items will not conform to v6, so when I change pose, the lingerie stays last the same place.
Thanks
Dit a quick check. Most items load correct under 4.8 (the undraped clothes follow the pose correct)
Except when adding the teddy4_string. That one does not conform correct when loading, but loads in the default T-pose. However when manually using "fit-to" (from the parameters tab), it adjusts to the G2F pose correct.
Thanks for taking the time to try it out.
None of the items worked for me. So i figured it must have been my install, had to uninstall studio and clothing control and then re-install.
All good now..
Thanks,
