Trouble with Install Application Path for Stone & Brick Texture Building Kit
TCR-3TCR-3 Posts: 16
Everything I download from DAZ into the Install Manager, normally goes automatically to the correct location path and installs itself.
Accept this one: Stone & Brick Texture Building Kit
It asks for:
  1. Name:
  2. Version:
  3. Bit:
  4. Path:
What do I select -OR- put in these boxes for Install Manager?
Thanks in advance,
-TCR
  • Richard HaseltineRichard Haseltine Posts: 111,996
    edited April 2022
    It has Bryce files, for which the placement is more complex, as well as Daz Studio presets. It also has the plain texture files. Make sure you are installing only the parts you need/want.
  • TCR-3TCR-3 Posts: 16
    Thank you...
    But I need to know WHERE to install it to (I am going to install the  entire pack so I can see what it is, how it works, etc.)
    Set the Bryce installation path in the Applications tab of Advanced Settings, but you won't learn much as they are wrapped up in a Bryce-specific format I think.
    Great thank you everone !
