transparency issue
NahpNahp Posts: 18
edited April 2022 in Daz Studio Discussion
Hi there,
I need your help, I try to find an answer to this : (see the picture)
On this, I want to see only feather but as you can see there is a part around... how can I fix it?
I try to change some paramters on surfaces, but nothing change...
Thank you for your help.
407 x 465 - 296K
Post edited by Nahp on
  • Richard HaseltineRichard Haseltine Posts: 112,089
    Is there a map applied to Opacity or Cutour Opacity, depending on which  shader is used? Is this an Iray render? Is it Daz Studio content or an imported mdoel from another application?
  • NahpNahp Posts: 18
    I think it is an Iray render...
    I found it... on object was superposed on the other...
    Solved.
    Thank you Richard, your message gived to me an other idea. ^^
