Can't seem to find the dForce Companion 2.0 pane any longer
Hi! Wonder if you can help me here. I purchased the dForce Companion 2.0. Had the first one as well. Haven't used it until the other day when I was looking for the pane in DAZ Studio 4.20. It's nowhere to be found. Tried to look for it in the tools section but the same there - nothing. Haven't seen anything that it's become obsolete or so. That's why I'm writing this ticket. Hope you can help me out here.
  • NorthOf45NorthOf45 Posts: 5,915
    There is no new pane. V2 adds adds functionality to the first version and replaces it. There is only the one pane. You should see "ManFriday's dForce Companion V2.0.2" and the release date in bold letters at the top.
  • barbultbarbult Posts: 27,620
    Did you look in the Window/Panes (Tabs) menu to load the dForce Companion pane?
    Did you check the Help/About Installed Plugins to see if  ManFriday's dForce Companion is listed and has a green checkmark by it?
    580 x 241 - 33K
  • VoxxaVoxxa Posts: 68
    Yes, that's where I started...
    As you can see, it'sw listed among the plugins but absent in the panes.
    688 x 1005 - 94K
    661 x 654 - 59K
  • Richard HaseltineRichard Haseltine Posts: 111,795
    And have you opend the dForce Companion listed in Window>Pane(Tabs) and checked to see if it says it is version 2?
    Sorry, didn't see that. I had to restore the tools to default, then it appeared in the list. sure wasn't there before I did that. Thanks for the note.
