3ds max to DAZ Studio - Selection Sets gone?!
Hey everyone,
first Post here (but be sure, scanning the forums for a while...),
just startet to create Props for Daz Studio and nearly everything runs mostly perfect...
Outside DAZ
Modelling - Fine!
Texturing - Fine!
Export -> Import - WTF?!
Inside DAZ
Material Setup (iray) - FINE! (GTX970 gotta lot of Work :D)
Lights & Camera - fine!
This isnt my first attempt for modelling, created a lot props for computer games (ages ago, remember Half-Life 1 Mods? :D), worked as an Imaging Technican, Photographer, Computer technican etc... but today i could crush my head onto the desk...
Maybe it just a "one click-problem" (yes, i need glasses.... they are ON!)
Working with 3ds max 2011, DAZ 4.7 and 4.8 Beta
Just tried to export a model created with Max, and import it in studio for rigging, dialog shows up, imported, brought the opacity up, tadaaa there it ist... got the right scale, no errors, fine... ....... thats what i thought...
opend up the figure editor, import the geometry (inside figure editor), no errors, geometry get listed.
as soon as i get an eye on the geometry editor, there are no surface selections set (created them in Max), groups or anything else, just 1 face group, 1 surface...
mkaaay, tried a workaround, tried FBX,
tried FBX with Sets switched on
tried FBX pre-rigged in Max (bones get imported, but without bindings and they´re out of the model) in short - unusable...
(in max, everthing is fine an usable...
What am i doing wrong, or what is the right way, create the Sets in Studio??! Pls, dont tell me im using the wrong modelling App, im used to max, own a licence for it and buying maya / carrara etc. is way out of budget...
We´re talking about simple objects, cylinders, boxes, guns, cars etc... gettin scared as im starting to think of some organic stuff with complex bone assignment :D
greets
Wommi
pls let me know if you need some screens or other info´s
Post edited by kommunikation_f92577edf4 on
    Yeah a screenshot of your import dialog box...
  • Richard HaseltineRichard Haseltine Posts: 112,066
    Are the groups and surfaces there if you reimport into 3DS?
  • edited May 2015
    ... as said... it could be that easy....
    maybe i should stop watching tutorials that are written/recorded ages ago..
    using the node weight brush solved (worked around) the Rigging-problem...
    thx to this one...
    https://www.youtube.com/watch?v=FOKTIW7anH8
    i´m gettin old :D
    New Technology -> New Problems...
    /update & info 4 other people out there,
    Selection/Face Groups are still gone as soon as i export, gotta do all the groups in daz studio, current pipeline:
    Do the Modelling in Max
    Export to OBJ with DAZ Export Setting
    Import in Daz via Menue ->Import Daz Setting
    Set the Opacity to 100%
    Finetuning the Scaling
    Switch to Geometry Editor
    Create the Facegroups
    Export as OBJ
    Clear Scene
    open the Figure Editor
    Import Geometry
    Create the Bones
    Assign Facegroups to Bones
    Create the Figure
    Do the weight mapping / finetuning bones etc..
    next wish 4 christmas: One Click Wonder Button 4 transfering thing between different programs.....
    greets wommi
    (just 4 the record... YES the "groups" button was checked... reimporting to max and selections/groups/tex etc. no prob...)
    481 x 394 - 38K
    edited May 2015
    The only other thing I can think of...that there's a space in the names.
    This naming convention will work...
    g hip
    usemtl 2_SkinHip
    but
    g hip
    usemtl 2 SkinHip
    Probably won't work.
    Or if there is a space in the material name/map..same thing. Something like Kd_map skin hip.jpg won't work.
    Post edited by mjc1016 on
  • edited December 1969
    double and triple checked that already...
    next funny thing:
    as soon as i detach the selected polys/faces in Max (splitting up the hole mesh into seperate objects), export the hole scene and import it in daz, it will show up as one Mesh with the Facegroups listed...
    buuuuut
    cause of the detaching, the vertices are broken up (by nature :D)... there is no option to weld vertices in DAZ, or am i wrong? this would speed things up a lot....
    In the past spaces haven't completely killed group names, but they have led to the rest of the name (after the firsts pace) being ignored -so in your example the name would be truncated to 2. Unless al of the surfaces and groups start with the same characters there would still be multiple groups or surfaces, just not named correctly and possible reduced in number.
    What are your export settings from Max? if you look at the OBJ file in a text editor, what do the g and usemtl lines look like?
  • edited May 2015
    a few more screens :)
    tried to export "faces, quads, polys" doesnt make a difference...
    Texturemaps are goin fine, its just that im missing my selections sets /face grouping to assign them to the bones...
    (last screenie)
    another hint, as soon as i manualy kill the usemat line, so there is only the g "groupname" left, theyre get listed correctly...
    in fact that will solve the first prob, buut that would kill any texturework on the model wich differs from the boning selections :D
    1858 x 903 - 111K
    495 x 363 - 30K
    393 x 224 - 20K
    295 x 438 - 24K
    1644 x 938 - 249K
