Can I reset the base 8.1 character?
I was trying to create a slider for a custom character but I somehow made my character the default 8.1 character. Now, every figure I bring in is based off my custom character and the results are, needless to say, bad. Can I reset my base 8.1 figure somehow? And yes, I did try to uninstall and reinstall the Genesis 8 Starter Essentials.
Thanks in advance.
  • Richard HaseltineRichard Haseltine Posts: 111,795
    1. Load the Dev Load version of the fiugre (should be in the same category as the standard base, or in the People>Genesis 8 Female>Developer Kit folder
    2. Find the slider for your shape
    3. Click the gear icon on the slider>Parameter Settings
    4. Set the default value and current value to 0
    5. File>Save As>Support Assets>Save Modified Assets - the only thing listed in the dialogue should be your morph, which is the reason for using the Dev load.
  • This puts me on the right path, but the funny thing is, the slider never made it, which is probably my problem. I can zero out all the sliders I used to create the custom character, but it's easily a few dozen. I'm guessing I'd have to set the default value to 0 for every one of them. Is that right?
    Thank you for the help. Even if it takes me forever, at least I know how to fix it now.
  • KainjyKainjy Posts: 916
    If you remember the morph name you can simply delete the morph file (located inside data directory)
    Well, you can replace steps 2 to 5 with:
    1. ...
    2. Edit>Figure>Zero>Zero Figure
    3. Edit>Figure>Memorise>Memorise Figure
    4. -
