Need help with skin textures! Please!(solved)
DH6602636-DH6602636- Posts: 22
Sorry for my bad english using google translate.
I found a really nice skin! Her skin is the best I've ever seen!
https://www.daz3d.com/ry-xara-for-genesis-81-female
But I don't understand why her feet are black, almost not the same color as the head, like the legs are roasted, I want to change his legs to be whiter.
But if I change the leg texture directly in Photoshop, it results in a body color mismatch (inconsistent seams), how can I change the overall skin tone? (leg and torso seams)
It's like exporting all the skins as a single image and then processing them in Photoshop.
Post edited by DH6602636- on
  • KainjyKainjy Posts: 913
    You must use software like Adobe Painter or Mari to edit the model (with all textures).
    Look for trial versions.. you will be able to do it following some tutorials.
    Adobe Painter: https://youtu.be/s0DhvFML7oM
    Mari example: https://youtu.be/9tZoeQXTX9Q
  • MelanieLMelanieL Posts: 7,865
    edited April 2022
    Her feet look perfectly normal in the promo pictures. You really should not need to alter the textures to get a correct result.
    Can you show an example of your problem (just her legs and feet from the knee down), or if you need to show the whole body to see the problem then please show her wearing clothes (a swimsuit or bikini will do) to avoid posting nudity here. And is the problem just in the viewport or in a full render?
    Edit to Add: Also please tell us which version of Daz Studio you are using.
    Post edited by MelanieL on
    thank you for your reply! ^^ I'm watching the tutorial :P
    Hi MelanieL :)
    Thanks Reply!
    Using DAZ3D version 4.15
    I checked her textures, darkened from the hips, added pictures in the attachment.
    the first with default lighting and Dome Rotation set to 100 (front).
    the second with a light placed directly in front of her.
    I did some comparisons on her torso and legs.
    560 x 720 - 316K
    560 x 720 - 287K
  • rosselianirosseliani Posts: 515
    edited April 2022
    I see a lady wich uses to wear short skirts, and that's why her legs are tanned...
    Try this method using Photoshop:
    1-Open the legs diffuse map in PS
    2-Duplicate the base layer
    3-Make the top layer the color you want, it will hide the "dark skin" layer
    4-Make a selection od the top of the legs, near the seam limit
    5-Modify the selection to make it progressive
    6 delete the progressive selection, the top of the "dark" layer will appear. delete a second time to make sure you deleted completely the seam limit area.
    7-Save as a Jpg
    8-Apply your new map
    Sorry, my Photoshop is in French, here are some images of the workflow I'm suggesting:
    1920 x 1080 - 143K
    1920 x 1080 - 153K
    1920 x 1080 - 160K
    1920 x 1080 - 140K
    1920 x 1080 - 192K
    1920 x 1080 - 220K
    Post edited by rosseliani on
    7-Save as a Jpg
    Hi rosseliani :)
    Thanks Reply!
    This solved my problem!
    Although the buttocks are still a little dark, it doesn't matter, thank you for making the teaching pictures!
    That's why I love this community! Everyone is helping each other ^^
    Hi rosseliani :)
    Thanks Reply!
    You're welcome! I'm glad to know this helped you!
