Uninstalling LAMH Player?
3DScreencraft3DScreencraft Posts: 505
edited April 2022 in Daz Studio Discussion
Hi all, I just got a notice that both the Player and the main LAMH are present, and I must uninstall on or the other. How do I uninstall the Player, please? I can't see it on my MS Uninstall list. Thank you! :)
Post edited by 3DScreencraft on
  • MelanieLMelanieL Posts: 7,879
    edited April 2022
    How did you originally install the Player - DIM, Daz Central, Daz Connect or manually?
    If you used DIM, just open up DIM/Installed Files and click uninstall - actually I would recommend you uninstall BOTH the Player and main LAMH then install just the main LAMH - I seem to recall this works better.
    I've no idea about Daz Central (never used it).
    I think you would follow similar process for Connect, right-clicking the product in Smart Content window and uninstall.
    If you did it manually, you'd need to track down what (and where) you installed and remove them manually, Again I'd probably recommend removing both and reinstalling full LAMH.
    Post edited by MelanieL on
  • Thanks so much MelanieL, found it in DIM, uninstalled both and reinstalled the main prog, and Daz seems happy. Much appreciated! :) I keep learning...
