question about figure scale and normal maps
StratDragon
In the past if Ive had to scale a figure below 100% of it's size it's often necessary to make the adjustments to the bump and displace values to compensate the changed scale. If I use normal maps do they adjust automatically to the figures scale or is there some setting I have to modify elsewhere?
Normal maps encode the components of the normalized vector normal to the surface. If you scale uniformly your mesh everything will continue to work without problems.
