I have some problems and I hope I can get help
1. The skin turned black when i daz to unrealcrying
2.the glasses is not attach my charactercrying
How can I solve these problemsenlightenedenlightenedenlightened
I  can't find Tutorials  about how to fix the problems 。
I wish I could get helpcoolheart
942 x 907 - 62K
919 x 784 - 26K
746 x 541 - 18K
  • For the glasses, create a head socket in the skeleton of your character. Then add the glasses as a static mesh component in your character blueprint and parent it to the socket. May require adjusting the position of the glasses.
    Not sure exactly what's going on with the skin texture, I would suggest taking a look at the material for the body since it works and compare it to the legs/arms materials and see what's different. They should all be using the same parent material and have diffuse/normal/roughness/etc maps plugged into the output.
  • GranvilleGranville Posts: 702
    It looks like the wrong texture map was plugged into the arms.
  • bitpartbitpart Posts: 30
    The color of skin in unreal is correct.
    If you want daz to show the same color, you should follow the picture below.
    And if you want change the color of skin, you can change the texture.
    282 x 399 - 47K
    thanks
    • Thank you. Problem solved
    you  are  right  ,it's my wrong
