Error loading PBRSkin Shader - solved
Singular3DSingular3D Posts: 669
Just installed Genesis 8.1 and the character Richard manually to my DS 4.15.
When loading Richard, I get an error regarding the shader file
data/daz 3d/built-in content/daz iray pbrskin/pbrskin.dsf
It seems that this file is not existing in my library. Where do I get it?
Thanks, Sing
Post edited by Singular3D on
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Did you install the update for the Default Resources when Genesis 8.1 came out, or since?
  • IceCrMnIceCrMn Posts: 2,333
    I don't have 4.15 to test, but I'm assuming the PBRSkin shader won't funtion at all on 4.15.
    I do have 4.12.1 beta installed and it dosen't work in that version.
  • Singular3DSingular3D Posts: 669
    I just looked into my product library and installed the Genesis 8 Starter Essentials stuff. I got Genesis 8.1 and could load it. It seems that the PBR skins where not part of it.
    How do I get this Default Resources? Do I have to use a newer Daz Studio version?
    Thanks, Sing
  • nemesis10nemesis10 Posts: 4,008
    Default resources should be in DIM etc....
    Ok,I never used DIM so far. So, I have an issue here.
    It will appear in any download/instal method - it's one of the packages that comes with Daz Studio, along with the Genesis # Starter Essentials and the dForce Starter Essentials.
  • AscaniaAscania Posts: 1,856
    Then you assume wrong. 4.15 introduced the ability.
    You're right, and the shader was added even earlier than that.
    I just had a look at the changelog....
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_15_0_30
    • Source maintenance
    • Update to NVIDIA Iray 2020.1.2 (334300.5582)
    • Added pbr_skin.mdl shader
    DAZ Studio : Incremented build number to 4.14.1.12
    I just didn't recall when users gained access to it and it became usable.
    Thanks to all. It was located in the Default Resources as part of the Daz Studio Download.
