• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Make Blender reveal vertecies assigned to multiple vertex groups [Solved]
lukon100lukon100 Posts: 853
April 2022 edited May 2022 in Blender Discussion
Is there a way in Blender to see a report of all verticies that belong to multiple vertex groups?
In my rigid model, I need each vertex to belong to only one vertex group, otherwise, Daz Studio will likely put some vertecies in wrong vertex groups and screw up the rigging. So I need to check for verticies that somehow got assigned to multiple vertex groups, before transferring my model to Daz Studio for rigging.
Post edited by lukon100 on May 2022
  • PadonePadone Posts: 4,314
    April 2022 edited April 2022
    Not that I'm aware of. You probably need a custom python script for that.
    But you can sort by bone hierarchy then quickly select/deselect in edit mode to check it.
    Or in weight paint there's "limit total" that you can use to get one group per vertex, but it's a edit function not a check so it will modify your actual groups.
    298 x 222 - 21K
    271 x 390 - 26K
    Post edited by Padone on April 2022
  • lukon100lukon100 Posts: 853
    May 2022 edited May 2022
    Thanks for your help, Padone.
    Well, until and unless I encounter a better way, this is my work-around:
    Make every vertex group it's own model in the Blender scene. This seems to be the only way to assure unambiguous vertex group assignment. One vertext group per model, and every vetext in that model assigned to that one vertex group.
    This method has so far worked. But it makes UV mapping pure hell, having all those separate models to UV map and manually scale against one another for consistency. I guess that once I confirm the vertex group assignment is perfect, I can re-unify the model for UV mapping. I will likely try this in a few days with a model I'm working on.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,336
    May 2022
    @lukon100 Sorry, I just now saw this:
    import bpy
    o = bpy.context.active_object
    bpy.ops.object.mode_set(mode = 'EDIT')
    bpy.ops.mesh.select_mode(type="VERT")
    bpy.ops.mesh.select_all(action = 'DESELECT')
    bpy.ops.object.mode_set(mode = 'OBJECT')
    for vertex in o.data.vertices:
        if len( vertex.groups ) > 1:
            vertex.select = True
    May 2022
    import bpy
    Thanks, The Mystery.
    So I assume this is a script to reveal verticies that belong to more than one vertex group.
    I intuit that "len( vertex.groups ) > 1:" is the condition in which a vertex belongs to more than on vertex group.
    If so, can another script be made to identify verticies that belong to NO vertex group, by the condition:
    "len( vertex.groups ) = 0:" ?
    May 2022
    import bpy
    Yes, your intuition is spot on, but it would be with a double equal sign, i.e.  "if len( vertex.groups ) == 0:"
    import bpy
    Awesome help from you, Mysteryis!
    Now I just gotta learn how to run custom scripts in Blender. I've never done that sort of thing before.
    May 2022
    import bpy
    1. Right click on the bottom boundary of the 3d viewport, and select Horizontal Split. Drag it up a little bit.
    2. Now go to the drop down on the new window's upper left corner, and select "Text Editor" or hit Shift-F11.
    3. Click "Open" and navigate to the script.
    4. Make sure your object is selected, and in object mode.
    5. Click the triangle pointing to the right to execute the script.
    It'll be left in edit mode, with your vertices of interest selected.
    May 2022
    import bpy
    Thanks again, TheMysteryIsThePoint.
    I got a chance to try the script. The "multiple vertex group" version found no veticies in my model. I guess I had none. But the "no vertex group" version found some, allowing me to fix them. Cool!
    May 2022
    import bpy
    Another check in the "win" column for Blender :)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
