How to use n-g-s-anagenessis-2-revolution on g8f or g8m
How to use n-g-s-anagenessis-2-revolution on g8f or g8m,
I am trying to find out how to apply this to any genesis model and also g8 models, it's pretty confusing so thanks a lot for any help
https://www.daz3d.com/n-g-s-anagenessis-2-revolution
  • IceCrMnIceCrMn Posts: 2,333
    I just tried it out on a G8F and the shader applied with no problems for me.
    All I did was select the G8F in the Scene.Then clicked the "Anagenessis2 Genesis 3" preset found in Shader Presets>N.G.S. Anagenessis 2 and it applied as usual.
    Is that not working for you?
    I found the freebie scripts the PA gave us.
    https://www.daz3d.com/forums/discussion/110976/n-g-s-anagenessis-ii-revolution-commercial/p1
    Should be able to get it going with these it won't apply directly to your G8 characters.
  • VicSVicS Posts: 1,273
    Ok got it, thanks!
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
    thanks,
    I didnt get the best result with this shader on G8F, maybe I did something worng, I have the vellus Horizon for g8f and that one I can see the difference in the skin more than with anagenessis-2
    My bad, I using the geo shell from daz menu, not the one from the vellus set, the set's one works fine, sorry about that
    edited November 2022
    wow was I wrong I tried the N.G.S. Anagenessis again and the difference it makes is obvious, I dont know what happened I didnt see it before!
    works great on genesis also,
    question if I modify genesis skin with Ultimate PBRSkin Manager for example after N.G.S. Anagenessis has been applied will that nulify the N.G.S. Anagenessis and visa versa if I modify genesis skin with Ultimate PBRSkin Manager then apply N.G.S. Anagenessis will that take out of the  Ultimate PBRSkin Manager settings I had ?
    thanks
    Post edited by VicS on
    is there any way to remove the N.G.S. Anagenessis once it has applied?
    it does make the faces of g8f look wierd sometimes , sometimes it looks fine too
    as for genesis
    really helps the skin and faces of geneisis out a lot I think
  • LeanaLeana Posts: 13,504
    Reapply the materials you used before Anagenesis.
  • charlescharles Posts: 866
    We were testing it for the first time the other day. On static sacnned people it was awesome..on g8 not so much. But depends on what shader your replacing it with. Without Dual Specular lobe I'm not really interested. I tried to make up for the same effects with extra layers and gloss.
    hmm interseting,
    makes some parts of g8 look wieird like gloss on the legs too
    but gonna say again, real happy with what it can do with genesis, i first have skin enhanced with the ultimate pbr skin, previously thats the best look I could get with genesis skin, the N G S tops it off, it doesnt look too bad
