Is there a way to change the text size in Daz Studio?
billyben_0077a25354billyben_0077a25354 Posts: 771
edited April 2022 in Daz Studio Discussion
My old eyes are getting older and the small text in DS is starting to get harder to read.  Is there a way to chang the text to a larger size in DS?
TIA
Post edited by billyben_0077a25354 on
  • IceCrMnIceCrMn Posts: 2,334
    Unfortunately no.Not in the current version there isn't.
    The best solution(only solution) I could find was to increase the Windows Scaling to 175%
    Right click Windows Desktop on any blank empty spot and select "Display Settings".
    Click the drop down menu called...
    "Change the size of text, apps, and other items"
    Set to desired level
    If you don't see any change in text size, you may need to logout of Windows and back in for the change top affect everything.
    At least you don't have to reboot for this one :)
    2563 x 1699 - 342K
  • cm152335cm152335 Posts: 421
    tips:
    use a second monitor with "lower" resolution than your main
    and detach and move (e.g. the scene window) on the second monitor,
