Only search 8.1 Expressions in Store ?
in The Commons
So I have run into the issue/scam where I have purchased G8F expressions that were listed when I only had "Genesis 8.1 Female" selected for catalog filter and found out that these expressions do not change a 8.1 G8F's face expressions ? Am I doing something wrong or this is expected?
If expected, how can I filter out Expressions that will not work on 8.0 faces? feels a bit cheated that they are listed on the 8.0 side but do not work. I can only get the Expressions that clearly state working on 8.1, to work.
Making the G8 base expressions (and any expressions that are using them) work on G8.1 requires removing dummy/placeholder expressions that are installed to G8.1 morph folders - These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading.
The dummy/placeholder files are located in;
...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files)
...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Expressions\ (24 files)
...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files)
...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Expressions\ (24 files)
Please make sure you are removing the files from G8.1 morph folders and not G8 morph folders.
Note; If you are logging in to DS and letting DAZ Connect (within DS) to install/update your content, you may have these also in an other location that has "\Data\Cloud\" in it's path
Note2; Do not remove any files from "FACS" or "FACSExpressions" folders
