Earring with joints - how to rig?
alaltaccalaltacc Posts: 151
I'm creating an earring with three "parts" connected by joints. I was able to create the joints, use the weigth map editor, etc, and make each part rotate/move independly. I also know how to use the transfer utility to "rig" a static, one-part earring to the G8F. My question is: how do I rig a jointed earring? If I use the Transfer Utility after creating the earring "bones", they are lost and replaced by the figure bones; if I do the transfer BEFORE, the earring inherits several bones from the figures in places that have nothing to do with the real joints.
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Use the Transfer utility, then use the Joint Editor to remove unwanted bones and add the new ones specific to the earrings (right-click menu), and then edit the weights.
  • SpaciousSpacious Posts: 481
    Or use a Rigid Follow Node.
  • alaltaccalaltacc Posts: 151
    I only had the time to test it today. It worked, thanks! It's a somewhat convoluted process in my opinion, but that's life. :-)
