Where to find the materials for traveler-s-naturals-tropical-coral-vol-2
Where to find the materials for traveler-s-naturals-tropical-coral-vol-2.
The product desciption says there are 15 color options-in product library only the geometry is there there are no options to change the material color
does someone know where the colors can be found?
thanks
https://www.daz3d.com/traveler-s-naturals-tropical-coral-vol-2
  • NorthOf45NorthOf45 Posts: 5,915
    Well... There's a bit of a problem with the compatible software list. The parts will load in Studio, but the materials are strictly Poser-only (mt5). You an set the colour directly if you want (there is a bump map you can add manually), or use some shaders to make it look alive and not bleached, although that is becoming the natural color of coral in many places these days.
  • VicSVicS Posts: 1,273
    The bump map is already included when the obj is loaded or where do I find it? thanks
    No, it does not load with the coral props, the material presets would take care of that, if they could. Volume 2 puts the bump map into the diffuse channel to give some detail, but it is very limited up close. Better to use a shader, like rock, or something that actually looks like coral.
    If the diffuse channel loads the same bitmap, it should be in the list of available files for the bump.
    If you are using DIM, filter for "Tropical Coral", then right-click on the product in question. Select "Show Installed Files..." and look through the list for /runtime/textures. Click on a file to open a file explorer at that file's location.
    OK iLL TRY IT SOON, THANKS
