Using Obj items with Simulations
I am trying to use an imported OBJ item in a simulation. I add the Dynamic surface to the OBJ item, but when I run the simulation the Obj item just disappears. Literally, disappears.  Any thoughts or ideas on what I need to do imported OBJ items with simulations?
  • Richard HaseltineRichard Haseltine Posts: 112,089
    That sounds like bad geometry. Is this a freebie you can link to, or a model of your own that you can upload?
  • SpaciousSpacious Posts: 481
    edited April 2022
    Without knowing anything about the item, or the scene you're using it in, it's hard to say.  Is there a floor plane of some kind for the object to land on?  Are there other items in the scene that your OBJ item should drape onto?
    You might try subdividing the OBJ, exporting it, and reimporting the subdivided object.  Then it will have more geometry for dForce to work with.
    Post edited by Spacious on
