Help!
Every time I buy something, It gets put in the wrong folder. I have a problem...I have hair. When I try to attach it to the g2f it says that the data cannot be found but when I look, it's in there. I'm not able to locate it so when the item comes in it comes in like a bunch of squares. What can I do?
Are you using the default location for DIM or did you pick somewhere else? If you picked somewhere else did you tell DIM to install there? If DATA does not go to the right place for the files to find it then you get the sort of errors our getting.
As Khory says, you need to tell DAZ Studio where the content is installed to.
If you are using DIM (DAZ Install Manager) then, by default, all of the content is installed to C:\Users\Public\Documents\My DAZ 3D Library
You need to enter that path in Edit > Preferences > Content Library > Content Directory Manager under BOTH DAZ Studio Formats AND Poser Formats.
Thanx for such a quick response! I saw this error in another thread and read up on it. Thanx for your help! Daz Team Rocks!
