Locked animations
Hello guys,
I've been doing some animations, and because of me using different models than the default genesis 8 models, some key frames need to be corrected. When I'm done correcting a key frame and go to the next one, the previous one resets, is there a way to fix this, because I don't want to render it frame by frame?
  • GordigGordig Posts: 10,837
    Are you using keyframe animations, or Aniblocks?
    Some of the animations are keyframe and some are Aniblocks. Can you tell me why is that important?
    The timeline and Animate are distinct from each other, so changes you make on the timeline won't reflect in the Aniblock. You'd need to bake the Aniblock to the timeline in order to make changes to it.
