I change the skin tone but the ears are in different color + picture
Hey there :)
I change my characters skin tone but when I do it her ears change it to different color for some reason.
How can I fix it?
Thanks!!! ^^
704 x 636 - 713K
  • IceCrMnIceCrMn Posts: 2,334
    Try copy the face to the ears, they are both on the same maps.
    Hey thank you very much , but how can I do it?
    On the Surface pane.
    Select Face
    Press CTRL+C on keyboard
    This copies the Face surfaces,
    Select Ears
    Press CTRL+V on keyboard
    This will paste them to the ears.
    Select Face
    Select Ears
    Thanks , I did it I press control C on face and go to the ears and press control V , it looks like its make the changes but nothing happen to the character.
    1206 x 755 - 844K
    Do the face and ears both use the same shader?
    Press and hold the CTRL button and you can select as many things as you want at one time.
    Use that trick to select the face and ears both at the same time to compare them.
    Both should be using the same maps and have mostly the same settings, except for things like translucency.
    can also try this incase the copy/paste from keyboard isn't working for some reason
    Select face
    Right click >Copy Selected Surface
    Select Ears
    Right Click>Paste Selected Surface
    Select face
    Select Ears
    Dudeeee your AWESOMEEEE!!! It works with the COPY SELECTED SURFACE!!!!
    THANK YOUUUU
    1117 x 643 - 795K
    You're welcome.
  • foxyfoxfurriesfoxyfoxfurries Posts: 394
    edited April 2022
    IceCrMn said:
    You're welcome.
    Sorry for that but I notice more bug when I put some blood or water on my model this happen:
    I think its the skin tone I use but im not sure  , its give me error when I put this tone skin
    1063 x 642 - 761K
    544 x 163 - 43K
    Post edited by foxyfoxfurries on
    edited April 2022
    foxyfoxfurries said:
    IceCrMn said:
    You're welcome.
    sorry its double mt massage
    The wet and tanned skins for G8.1 shader is custom.
    So to use it, the skin surfaces must have it applied or you will get the errors you show in your screenshot.
    I have the older one, so I'm not up to date on how to use the newest versions.
    The error says you can select your skin surfaces and apply the shader to fix it.
    On the Surfaces pane you should see a premade grouping for all skin surfaces called "Skin"
    Select it, then apply the wet and tanned skin shader.
    I'm not sure about the blood effect works, I don't have that one.
    Ok thank you! I tryed everything in this and its just dont work on my model : /
    Maybe you have good idea for nice skin tunned for genesis 8?
    Skin settings have been the subject of much discussion actually :)
    There's a huge thread in the commons about it with lots of tips and examples.
    You should look there for better advise than I can offer.
    I'm still working n that part myself.
    I'll look to see if I can find it.No one has posted to it for a while, so it's probably buried a few pages deep by now.
    Anyway, here is the most recent best skin I've done.And it's still not working for me as I want.
    Depending on how the light hits the character, it has light terminators( see the legs), most likely from the normal maps, and I haven't got the SSS correct either.
    3000 x 1854 - 869K
    Well it looks awesome!!! I mean she have very nice skin I like it a lot :)
    My model was a little bit pale but I found some video that help me a lot and now her skill looks a lot better.
    This video :
    Daz Studio Skin Color - Basic - YouTube
    But wanted to use some other style as well ^^
    If you find something better please let me know
    Thank you.
    It does look better in png format instead of the jpg the forum uses for images.
    So there is some jpg compression artifacts in it.
    I'll watch that video also.I'm still learning :)
    I found that thread I mentioned.
    https://www.daz3d.com/forums/discussion/54239/fiddling-with-iray-skin-settings/p1
    It was started in 2015 and iray has changed over the years.So some of it may not be of good use today.
    also we have new PBRSkin shader that works different from the iray base shader that is used in that thread.
  • IceCrMn said:
    Thank you.
    Your more then welcome nice works!
    And check this video its may help you , great way to change skin color without any bugs.
    And what you sent me very interesting I will take a look now!
    Thanks! And again if you have some more stuff for change skin let me know please even from the DAZ3 Shop , I always buy anyway ^^
