Genesis (1) Where are the materials?
Using original Genesis...
It seems to me there used to be materials associated with this figure, but now - not so much. Is there a skins pack (preferrably free) I can get for this character?
Alternately is it compatible with other genesis textures, like 2, 3, or 8?
457 x 497 - 24K
There is this:
https://www.daz3d.com/genesis-starter-essentials
It should come free with DS but Starter Essentials for the different Genesis figures need to be downloaded and installed separately, AFAIR. Don't recall how but I think they're being added to your product library (as well as DIM and DAZCentral/Connect) when you "purchase" DS.
Genesis 1 can use V4 and M4 textures out of the box. There are many freebie textures available for those characters.
Genesis 1 can't use Genesis 2, 3 or 8 textures out of the box. There are products available to enable that though:
https://www.daz3d.com/genesis-2-male-and-female-base-uvs-for-genesis ==> enables you to use textures for Genesis 2 using G2F and G2M base UVs
https://www.daz3d.com/victoria-6-and-michael-6-uvs-for-genesis ==> enables you to use textures for Genesis 2 using the V6 and M6 UVs
https://www.daz3d.com/genesis-3-uvs-for-genesis ==> enables you to use textures for Genesis 3 using G3F or G3M base UVs. It should also work with textures for Genesis 8 using G8F and G8M base UVs, but it won't work with textures using 8.1 UVs.
