ISO: City Highway
MJ007MJ007 Posts: 1,718
Hello all,
I am in search for a city highway and came across this set:  https://www.daz3d.com/divided-highway
Since i am an older DS user, i plan to convert this using DSF Toolkit (since its fine as a prop), so i want to know how many parts this will be AND how well are the maps named since i will have to load them manually?  Which is always the tough part in most cases because if the names dont reflect within reason as to where its applied... it becomes completely guesswork!  Although this is kinda an expensive set for a just divided highway, it is perfect for my purposes for it.... unless someone is aware of something else that looks like this for a cheaper price tag or already setup to use in older DS/Poser versions.
Thanks In Advance!
-MJ
  • memcneil70memcneil70 Posts: 6,172
    I have it, and wow, I opened it up and expanded it. But I have to leave my house for about a half hour right now. I would be glad to make screen shots of the scene info if no one else is able to answer before I get home. I can tell you it loads as two versions, a full 3DL and an Iray one. No separate props.
    Mary
    I hope this will help you MJ007.
    586 x 579 - 19K
    359 x 602 - 30K
    365 x 624 - 31K
    364 x 635 - 24K
    358 x 626 - 31K
    367 x 633 - 32K
    364 x 632 - 32K
    382 x 222 - 12K
  • MJ007MJ007 Posts: 1,718
    edited April 2022
    Thank You, but can you please screenshot the Surfaces tab?  Also, its more important to see how it loads from the Figures/Props tab.  I hope the majority of the set is contained within 1 .DUF/DSF.
    -MJ
    Post edited by MJ007 on
    Didn't see your request due to Cloud Flare issues. I have the load set info for you. I started to make surface tab screen shots, then thought I should ask if you want the 3DL or the Iray version first. Because each element is about 4 screen shots each.
    This is what I have done for the highway surfaces are also attached so you can look it over and see if it will work for you.
    Mary
    748 x 901 - 123K
    509 x 934 - 74K
    487 x 901 - 82K
    481 x 875 - 59K
    475 x 896 - 56K
  • FirstBastionFirstBastion Posts: 8,087
    There are two full preload scene files,  one for Iray and one for Daz 3Delight. The scenes load with lights and cameras and all ready to render.
    Mary
    This is actually good enough.  Its only one .DUF file so once converted, it will be just one .OBJ file to import most of the scene into, if not all of it.  Ill just have to figure the maps out manually which is NOT a fun task, but managable with time.  My system would be using the 3DL version.
    Many thanks!
    -MJ
    edited April 2022
    "The Man" has spoken!  Looks like i can manage it fairly once i get it converted.
    -MJ
    Just call me Bill.
    cool!!
    -MJ
     Not exactly sure what this conversion process entails,  but I should make it clear that the entire scene loads with one click,  but it is not a single figure,  but rather over a hundred plus props parented together. I do it that way  because I like leaving the option of tearing apart and kitbashing open to the artist.  Whereas a figure does not allow for that. Just thought I would make it clear so there are no surprises.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,766
    just warning, if going to Poser via DSON you will be OK but obj export you might have some issues with UV wrap, I don't know about the DSF tool kit
  • xyer0xyer0 Posts: 6,522
    Divided Highway and Tunnel Traffic are awesome! What a great service to Daztopia they provide. And in these times, near-empty highways are looking more believable. I was able to get an offramp from KitBash3D's Highways set.
