zBrush not appearing in Daz after GoZ Install
I have installed the plugin from DAZ Central, but ZBrush is not showing as an option in Bridges nor Send To.  I had both closed when I did the install.  I have also uninstalled and re-installed to no avail.
  • Richard HaseltineRichard Haseltine Posts: 111,234
    Daz Studio has an issue with saving layouts in 4.20.0.2, that seems to affect isntalling the script-based bridges but I am not sure it would affect a plug-in like GoZ. Is the plug-in listed, and enabled, in Help>About Installed Plugins? Assumign it is a fresh download, is Daz Studio also the current version (4.20.0.2 - sadly the one with the layout-saving bug)? Daz-branded plug-ins must match the version of the host application.
  • Yes, this ia a brand new install and is 4.20.0.2.  I guess the layout bug is affecting this as well.  I just did the install via DazCentral.  There was not a version that I could find for this plugin.
  • It is working now.  The problems was widespread to all downloads and installs.
  • edited December 2022
    Hi, how did yours work again? Did you do something? Mine didn't work again, I've done practically everything but the problem persists.
    GOZ cannot find the path of the executable, and the path is correct.
    Thanks for the help!
    Hey, did you ever find out what was wrong? Looks like im having the same problem... Thank you in advance!!
