Daz 4.20 don´t use the GPU anymore
Hi there, I know there are some topics closer to this one but no one answer the question.
I have a NVIDA GeForce MX110 (Windows10 64) and I´ve used to render my scenes pretty well in Daz4.15 with GPU , but since I´ve moved to Daz4.20 although the render pannel recognizes and show my GPU as an option DAZ is just using the CPU even with a very low memory scene lika a gray plane and a grey sphere. If I disable CPU option, and or CPU fall back, I just get a transparent or black render in seconds.
So what I know its NOT the problem:
- scene memory: tested with old scenes rendered with GPU and new ones very simple
- GPU fail: it is regognized by DAZ and other software uses it nicelly
Help is welcome.
Thanks
  • areg5areg5 Posts: 617
    What nvidia driver are you using?
  • Hi,
    Driver - NVIDIA   451.67  DCH   (Windos 10 home 64-bit)
    NVIDIA CUDA 11.0.208 driver - 27.21.14.5167
  • Richard HaseltineRichard Haseltine Posts: 111,677
    The card apparently has only 2GB of ememory https://www.techpowerup.com/gpu-specs/geforce-mx110.c3044 If that is correct it may well fail on even very simple scenes.
  • SpaciousSpacious Posts: 481
    I think the new verion of Iray that's included in DAZ 4.20 requires NVIDIA driver 465.89 or higher.
    Thanks,  but with Daz 4.15 I rendered with the same GPU quite busy scenes.  Its not that.
    Hi Spacius,
    Thanks a lot for the tip. Although it seems simple some users (me) are not aware.
    Intaled NVIDIA 512.15 DCH, seems to be working now.
    Cheers.
  • stefan.humsstefan.hums Posts: 141
    bvcastilho said:
    Hi,
    Your driver is outdated and not supported by Daz Studio 4.20 Iray.
    Minimum driver requirement for GPU rendering is 471.41.
    Sorry, I misread the driver version.
    stefan.hums said:
    bvcastilho said:
    Hi,
    Thanks, updated to driver version 512 and it worked.
    Cheers.
    No problem, thanks for the attention.
    its working now with driver version 512
    Cheers.
