Always opens the hip node - why ?
Hello
When I select genesis character in a viewport it always expands hip node in scene tab. Why is that !? and how to avoid it. It's a hassle because i always have to collapse the hip in scne tab.
By,
  • TaozTaoz Posts: 10,371
    edited April 2022
    Right click on the head, then you should get a Select "(character)" option.
    Post edited by Taoz on
  • vudrigavudriga Posts: 6
    Thanks Taoz, but it's still tedious.
  • GordigGordig Posts: 10,818
    Try double-clicking the character in the viewport.
  • Richard HaseltineRichard Haseltine Posts: 111,795
    If you want to select just the figure there are a couple of options for Node Selection in the Tool Settings pane - one, which is the default, is to select the Figure on the first click and then the bone under the mouse on the second; the other is to select only the figure, regardless of its current selection state.
