dForce error(SOLVED)
barrieMbarrieM Posts: 307
edited April 2022 in Daz Studio Discussion
dForce quits during simulation. Can anyone please see if the error can be pinpointed from the attached log file.
Mac Mini OS 12.2.1 Monterey: 68GB Ram. No GPU.
1396 x 862 - 327K
Post edited by barrieM on
  • DaventakiDaventaki Posts: 1,624
    Not enough memory is what I see.
  • barrieMbarrieM Posts: 307
    I thought 64GB memory was enough. However, I discovered that dForce does not simulate only the selected object. Since I had seven clothed characters in the scene dForce crashed, Hiding all but one item cured the problem.
  • Richard HaseltineRichard Haseltine Posts: 112,089
    If you never want to simlate certain things (moving or as collision targets) you can turn off Visible In Simulation, which doesn't have to be turned back on again to render the way the overall Visible property does. Alternatively you can select everything involved in the simulation (both the objects that will be modified and the objects they will collide with) and from the Simulation Settings option menu you can use Simulate Selected..
    Thank you again Richard. I didn't explore the dForce options. Your suggestion is the preferred solution.
