Genesis to Genesis 2
RCTSpankyRCTSpanky Posts: 850
I know it is possible to use Genesis 2 Skins on Genesis or to convert Michael 4 Skins to Genesis 2 with the right tools ("Batch Convert Genesis 2 to Genesis" or "M4 Skins Batch Converter to Genesis 2 Male(s)")
But I want do convert a Genesis Skin (Braxton for M5) to G2M. is that possible too? Thanks for your help in advance.
  • TimbalesTimbales Posts: 2,451
    Assuming he uses the M5 UV, you don't need to convert any of the skins. The mat pose that comes with the character won't work, but you can apply the skins manually.
    What I usually do is load my Genesis figure, apply the mat pose I want to use, then load G2M and copy the surface settings from Genesis to G2M.
    You do need to make sure that the base shader being used is the same...Daz Studio Default, omUberSurface, etc.
