Optix setting?
edited March 2022 in Daz Studio Discussion
Where can I find [the Optix setting] it? Where is it?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,854
    edited March 2022
    in D|S4.12 and below actually I thought 4.11 is the reason I use 4.11 with my GTX card so I can disable it but some use 4.12, I guess it depends which version
  • So it's outdated and not included in 4.2?
    edited March 2022
    you mean 4.20 I assume  it's a version number not a decimal
    4.2 did not even have iray wink if it existed, I think we started with 4.5
    think it went missing long ago, I rolled back a version of 4.12 to 4.11 get it
  • stem_athomestem_athome Posts: 526
    edited March 2022
    Have a look here:- https://www.daz3d.com/forums/discussion/comment/5099106/
    Post edited by stem_athome on
  • IvyIvy Posts: 7,165
    edited March 2022
    You can only control opitex-prime acceleration if you are running daz 4.12.0.83 or older and gpu drivers 4.36.30
    NVIDIA changes how Opitex worked in the GPU for the raytracing in RTX gpu architecture which in turn changed how opitex worked in the GTX gpu cards architecture being  that opitex is set as always on by the gpu driver.
     so if your using a new RTX gpu & or your running daz studio newer that 4.12.0.83 OR A NVIDIA driver newer that 4.35.30 than you will not be able to turn off the optiex in daz studio
    But if  you are running a GTX gpu with daz  4.12.0.83 or older and gpu drivers 4.36.30 then you will be able to
    477 x 841 - 40K
    459 x 120 - 15K
    Post edited by Ivy on
  • kyoto kidkyoto kid Posts: 42,501
    ..so basically if you are using any version above 4.12.0.83 and the latest driver, you are stuck with Optix always on if you have a pre-RTX card..
    edited April 2022
    well I have the latest driver and 4.11 uses just over 1GB VRAM less than 4.20 beta on every scene
    often more
    I am rendering something now GPU-Z says 3400MB, 4.20 it will come close to 6GB every time
