dForce Medieval Peasant vs Beorn
MelissaGTMelissaGT Posts: 2,611
edited March 2022 in The Commons
Can anybody with this outfit tell me how many material zones the vest has? https://www.daz3d.com/dforce-medieval-peasant-for-genesis-8-males
I'm considering a purchase just to use the vest in a kitbash and I'd really like to know ahead of time if this outfit will take to tiled shaders. I'm aware that I can just define new material zones with the geometry editor, but if the UV map is wonky, they won't line up coherently for me to make seamed sections, such as front/back/borders, etc. I recently kitbashed an outfit together and used the vest from this one (https://www.daz3d.com/beorn-for-genesis-3-males) and the UV map is...well let's just say it doesn't take to tiled shaders all the well at all in the shoulder area and unfortunately the piece I'm working on is close-up so it needs to be gud gud in the shoulder area. Both outfits are by the same PA so I have to wonder if the UV maps are laid out in a similar fashion.
I have ZBrush - would it be difficult for me to change the UV map? I've never done that before. Ideally what I want is to have a seam across the shoulder between where you'd sew a front piece to the back piece...but the UV map as it is now the only place I could define a straight line is kind on the front below the shoulder (the tiled shaders do a kind of tilt-flip-thing along the line I defined). Here's what I've done to the Beorn vest as an example...see the yellow line...that's where I'd like to be able to place the seam but with the way the polygons are laid out I couldn't. The only place I could do a straight line across was where I added the fur across the upper chest.
Post edited by MelissaGT on
  • GordigGordig Posts: 10,832
    edited March 2022
    Pants: PantsFabric and Waistband
    Tunic: NeckCollar, SleeveCuffs, TunicFabric, TunicLaces and TunicSleeves
    Boots: BootBackstripe, BootLeather and BootSoles
    Headpiece: HeadpieceLeather
    Vest: VestFabric
    Bag: BagLeather, BagStrapInner, BagStrapOuter, BeltLaces, FrontLaces, FrontLacesBase
    Belt: BeltLeather
    Whoops, just noticed you were only asking about the vest.
    Post edited by Gordig on
    edited March 2022
    Vest: VestFabric
    Belt: BeltLeather
    Yeah looks like it's just a single material zone. I bet it's almost identical to the way the Beorn vest is laid out.
    I think I just need to keep playing with the geometery editor on the Beorn vest.
    Thanks!
