Cleavage Clothing Issue
Hey there! All of my female renders have this issue--regardless of if the fit is dForce or not. Any idea how to fix this?
1246 x 849 - 1M
  • felisfelis Posts: 6,502
    That is a common problem, done by projection morphs, when the character is dialed in, usually caused by (very) large or (very) small breats.
    Even with dForce is shall be avoided to have this prior to simulation. With dForce it might be avoided if using timeline, and then at the start of the timeline dial the breasts down, and then mid timeline dial the breast up to the wanted shape.
    You can also consider https://www.daz3d.com/projection-morph-manager
    as it tries to deal with projection morphs. Whether that can solve your breast problem I don't know.
  • AndrewJJPAndrewJJP Posts: 779
    Currently I fix this with custom morphs created in Blender or dForce, sometimes both, depending on the situation. If you are comfortable with editing geometry in Blender and want to go that route, I can give you an approach that will work with most clothing... but I wouldn't learn to do it just for this.
  • TogireTogire Posts: 457
    You should look at https://www.daz3d.com/sy-clothing-breast-helper-genesis-8-female
    It is specifically done to solve this problem.
    Also, you can try to simulate the cloth. Depending on the dforce parameters, it can completely fix the problem.
