What is the best way to improve detail in my renders?
  • rnollmanrnollman Posts: 310
    When a render gets above 90% is it worthwhile to wait until it reaches 100% or it is pretty much done?
  • Richard HaseltineRichard Haseltine Posts: 111,795
    The percentage is how close it is to the target convergence ratio - 95% by default. How doen that is will depend on the image, and on where the remaining noise is. There is no absolute answer.
  • barbultbarbult Posts: 27,620
    You can get a much sharper image by changing the Render Settings values for Filtering. Default is Gaussian 1.5. Try changing 1.5 to 0.85. or Change to Mitchell 1.0, or even Box 0.5.
  • SpaciousSpacious Posts: 481
    Have you tried changing the Iray Compression settings in the Advanced Tab of the Render Settings?  Doubling or even quadrupling both the values will make a huge improvement in renders, but it will also increase how much vRAM you need, thus increasing render times, and possibly causing a render to go to CPU when it used to fit on GPU.
