making d-force clothes look looser?
I am sure there's a way to do this but I'm not sure what I'd need to change in the settings.
I am wanting to make it look like the clothes on my character don't quite fit right
    If you are familiar with settings, go to the dforce surface adjuster (in edit > geometry > dforce surface adjuster .. this is from memory, mileage may vary)
    You can maybe expand it a little bit and make it a tiny bit silkier and stretchier.
  • WillowRavenWillowRaven Posts: 3,787
    Let us know if this works, please. I've often wondered the same thing.
    The contraction-expansion ratio will also help. Default is 100%, which is no change, but increase it slightly to 105% or 110% and see what happens.
  • Faeryl WomynFaeryl Womyn Posts: 3,777
    Waits and watches intently.
  • RGcincyRGcincy Posts: 2,864
    You may find some help getting looser fitting clothes in these examples I've posted: Loose and Rumpled Clothing, SocksPuffy Sleeves, and Men's Underwear.
