Joanie pictures settings and exporting to Poser
vajrabairavavajrabairava Posts: 1
Hi everybody,
I've two questions:
1) I've been trying to reproduce the images where Joanie HD is presented in this site http://www.daz3d.com/fw-joanie-hd. The description specifies "no post work done, apart from compiling the images".
Is anyone kindly indicating the light and rendering setting (and other further tricks) able to get this of result?
2) Please indicate the correct procedure to export V6 and Gen2 characters to Poser.
Thanks a lot
  • Richard HaseltineRichard Haseltine Posts: 111,363
    1) Lights will be the big thing, as the FW skins are generally set up for a slightly unusual lighting system. Some of their characters include lighting sets, though this one appears not to.
    2) Assuming you are using Poser 9 SR3, or Poser pro 2012 SR3, or later the DSON Importer will let you import content into Poser as long as there are Poser Companion Files (and in some cases, using the Dimension3D script, even if there aren't PoserCFs).
  • vajrabairavavajrabairava Posts: 1
    Thanks a lot. I'm using Poser Pro 2014. As you've specified for the Joanie pics, FW needs unusual lighting system. Any idea anyone?
