Just curious: what setting specs do you guys use for best quality iray renders?
Am curious what settings you use for iray renders you want to make look as clear and hd as possible on your systems. What single setting do you find is most important for you in particular to achieve this?
  • IceCrMnIceCrMn Posts: 2,333
    I start with these and adjust as needed.
    Sometimes I use the "Box" pixel Filter with the Pixel Filter Radius set to 0.05.
    To my eye "box" set to 0.05 or "Triangle" set to 1 give the sharpest images with the least amount of fuzzy/jagged edges.
    Of course, lighting in your scene is the most important part, just ahead of, but not replacing composition.
    497 x 1037 - 126K
    For interior scenes, setting the "cm^2 Factor" to 10
