poser edit dependencies didnt work in daz studio?
AnymatterAnymatter Posts: 95
greetz members...
i've created some slave dials( from conforming figure ) to be controlled by master dials(from target figure) by using the edit dependencies in poser. everythings work fine in poser not until i load the conforming figure in daz studio. some of the relation between slave and master dials worked and some did'nt . i wonder if its a bug with simple solution? appreciate any help n thx!
  • Richard HaseltineRichard Haseltine Posts: 112,047
    As I understand it the PZ3 importer works one item at a time, converting to native forms, so any between-figure linkages are lost. If the slave and master have the same name (not label) then DS will link them itself, if not you will need to rebuild using the Edit mode in the Parameters pane and the Property Hierarchy.
  • AnymatterAnymatter Posts: 95
    great!after playing around with internal name for each morph dials in poser which i believe its called name/label in daz studio, cross talkng figure works like a charm .thx very much for the help!
