Where is the Joint editor in DS 4.20.
I want to move a pivot point on a prop. I understand it can be done with the joint editor but it does not appear under the tool menu of my DS 4,20. The short cut, shift > option > J also refuses to produce the Joint editor.
Where is it?
472 x 576 - 198K
  • NorthOf45NorthOf45 Posts: 5,915
    Should be there. Try, from the menu, Window -> Workspace -> Update and Merge Menus. If that menu item is missing, then there is an Update and Merge Menus script in the Library under Scripts -> Utilities.
  • GordigGordig Posts: 10,820
    Can you switch to it in the Tool Settings pane?
  • Richard HaseltineRichard Haseltine Posts: 111,831
    That looks as if you haven't entered your serial number (in Help>About Isntalled Plug-ins), so you don't have the Daz Studio Pro tools enabled.
  • barrieMbarrieM Posts: 307
    Thank you Richard, NorthOf45 and Gordig. Many of the tools were not enabled. Problem solved.yeslaugh
