Content won't show
ViperwitchViperwitch Posts: 0
I am using DAZ 4.5 Free version 64-bit on windows 7
When installing Victoria 4.2 from .exe bundle files would not show in content folder at all.
content folder shows as empty.
When trying to manually import says ''here are no files to import''
Previously used bryce 5.5 with daz 1.5 on win vista SP2
Had no problems.
Now daz 4.5 64-bit won't get content to show.
I want to buy some items here, but if i can't load what i got already can't buy new obviously
Please do you have any idea why it is not showing?
Even tried brand new folder in /C/Users/My Documents. still won't work.
thank you
    Why not use DIM (DAZ Install Manager) to install your content?
    It will get you the latest versions of everything in your Product Library, and download and install it for you. It will even offer you the updated versions of any of the products that you own once they become available.
    The latest version of DAZ Studio is 4.7, is there a reason that you are not using this?
    Where did you install V4 into. If you have a content library, and you know the path to it, you will need to tell DAZ Studio where that library is. Go to Edit > Preferences > Content Library > Content Directory Manager, and enter the path under BOTH DAZ Studio Formats AND Poser Formats, then you will see your content in the Content Library pane.
    Smart Content is controlled by Metadata, but that is another story, try what I have suggested above, and the content should at least show in the Content Library pane. V4 will be under Poser Formats.
  • frank0314frank0314 Posts: 15,116
    Had no problems.
    thank you
    Did you happen to has DAZ Studio open when you installed? If so and installing manually re-import your metadata
