How do I set a new UV map for the Cube Primitive?
FMM_UWF_6b886030dbFMM_UWF_6b886030db Posts: 24
So I load up the New Primitive: Cube.
I set each side to its own Material.
Now, I want to make sure that, instead of each side taking up 1/6th of the default UV map, I want each side to have its own full-area UV map.
As in, you set a diffuse to a side and that entire picture takes up that side, INSTEAD of a the default "fraction of the pic showing and then having to tweak the Horizontal and Vertical Tiling to get the whole texture to fit".
Is there a way to do it directly in DS without having to open it into a separate editor/UV mapping program?
  • Richard HaseltineRichard Haseltine Posts: 111,984
    edited April 2015
    You could adjust the tiling settings in the Surface pane, so that the image was shrunk to fill the face just once. You'd want to set Vertical tiles to 2 and horizontal tiles to 3.
    1570 x 727 - 116K
  • FMM_UWF_6b886030dbFMM_UWF_6b886030db Posts: 24
    Actually, that's exactly the thing I DIDN'T want to do.
    I wanted to change the UV mapping ITSELF inside DS (without having to run an exported OBJ through UVMapper or some unwrapper in a separate 3d modeling program), so that I WOULDN'T have to change the tiling settings.
    DS isn't a modeler, so as far as mapping tools go, it has less than basic ones.
    In order to do anything other than tiling, it will need to be run through a modeler/UV mapper.
    Or, even better, build a cube and map it in a modeler...the primitives in DS are just too basic, without outside 'help'.
    I had a cube, six material zones, each one a separate UV map...so each face was its own map and zone. I'm not sure if I can find it, but if I do I'll throw it up somewhere.
    What are you wanting to achieve? If you want to make each face a separate surface, so that you can use different maps on each (with the tiling trick) use the Geometry Editor tool to select all the polygons of one face, right-click, Geometry Assignment>Create new Surface from Selected and give it a name. Repeat for four other faces, leaving the last assigned to the original surface, and you can texture each separately.
  • leo04leo04 Posts: 414
    Very helpful, thanks.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,805
    edited January 2025
    I know this thread was necromanced but for anyone out there
    the default DAZ cube has terrible UV mapping
    there is an unassigned strip all along the right side as seen in my "template"
    (well maybe if the forum could do dark mode cheeky)
    you are better off importing a different cube or creating a new UV elsewhere then loading it under surfaces in the striped box/hamburger  menu
    2048 x 2048 - 267K
  • crosswindcrosswind Posts: 10,356
    edited January 2025
    Agreed ~~
    But default Primitives come from dzPrimitives plugin... all geometry and UV data are in RAM before saving scene file and/or Prop asset.  So even if one re-maps a new UV and create a new UV Set saved with Prop asset, it has nothing to do with the default create Primitives functions from the plugin...
    That was probably why Sickleyield made this product... IMO : https://www.daz3d.com/sy-morphing-primitives-and-merchant-resource in which all primitives are with remapped UV sets
    Post edited by crosswind on
  • bugbearbugbear Posts: 17
    Necroing this thread to offer my profuse thanks to WendyLuvsCatz for that template (and to crosswind for reminding me that Sickleyield product exists).
    Thanks to the template, I'll be able to bang out simple buildings like this for filling out skylines without over-taxing my ancient machine:
    800 x 666 - 268K
