My Installing failed
when i ran the install manager 3 things didn't install
one of them i don't care about but this is what came up when i tried to install the other 2
Install Manager cannot find a required path. The package for "GoZ for DAZ Studio 4.7+ (Win 32-bit)" requires that the installed path for "DAZ Studio 4.5 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
I\
Install Manager cannot find a required path. The package for "Scene Builder for DAZ Studio" requires that the installed path for "DAZ Studio 4.5" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
i'm not sure ho to get the path for "DAZ Studio 4.5"
First of all, the GoZ plugin is only of any use to you if you own ZBrush
Click on the little Gear icon at the top right of the DIM (DAZ Install Manager) and in the Applications tab, list the path to DAZ Studio. If you are on Windows, it should be in Program Files if it is the 64 bit version, or Program Files (x86) if it is the 32 bit version.
In Windows, right click on the DAZ Studio icon on the Desktop, select Properties, and then copy the file path from the 'Target' box and paste that into the Applications tab in DIM.
