How to genesis 8.1 skin transparent.
Hi to all
I'm trying to make genesis 8.1 skin transparent but I can't find no "Opacity" pane in surface tab. Can someone explain me how to make that, please?
Thanks
  • abe01abe01 Posts: 29
    there is a parameter called 'cutout opacity'
    push the slider to 0
  • Richard HaseltineRichard Haseltine Posts: 111,831
    It depends on the shader used.
  • SpaciousSpacious Posts: 481
    As Richard said, the PBR skin shader used for most Genesis 8.1 characters specifically, and some other shaders, doesn't have a Cutout Opacity parameter.  It also doesn't have Refraction, which is really the better way to make things transparent rather than invisible.
    Not sure quite what you're trying to do, but if you select the surfaces that you're trying to make transparent and double click the IRAY UBER shader you'll get both of these options for those surfaces.
  • riomairiomai Posts: 44
    Thanks to all :)
  • vozolgantvozolgant Posts: 207
    edited June 2022
    We need a cutout opacity node on the 8.1 PBR skin shader. Without it, we can't get 3rd party genitalia using IRAY Uber Shader to look the same as the 8.1 Skin of the PBR Shader. I'm really getting sick of DAZ Studio. I wish we had a better solution.
    Post edited by vozolgant on
  • BejaymacBejaymac Posts: 2,010
    Learn to use the ShaderMixer, the PBRSkin shader was made in it therefore it can be modified in it.
