ERR
Naughty-GNaughty-G Posts: 8
edited April 2015 in Bryce Discussion
My old PC is out-of-memory error appears.
Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz、2667 Mhz 4 core Memory 3G
Post edited by Naughty-G on
  • HoroHoro Posts: 11,688
    @Koich - sorry to hear that. i7 920 is quite fine (that's the one I use) but 3 GB memory is very meager, Win 7 uses already around 2 GB. Bryce can use 2 GB too, and if made large address aware even more than 3 GB. Give your machine at least 6 GB.
  • SixDsSixDs Posts: 2,384
    To add to what Horo has said, that only applies if you are running a 64-bit operating system. If you are using a 32-bit OS, the most that you will be able to address is 3.5 GB of memory, so increasing the amount of memory will accomplish nothing. Under those circumstances the only option is to try and reduce the memory loads of the scene.
  • Naughty-GNaughty-G Posts: 8
    Thanks for the advice.
    32-bit I think as there is a limit.
    I consider the introduction of 64-bit.
