g8 male elbow distortion
Im having problems with my g8 male figure. When I bend the elbow, it distorts it, it doesnt matter which character. Even if I start with no morphs at all, it still does this.  Any suggestions? It never did it before now its every time
571 x 591 - 69K
  • GordigGordig Posts: 10,797
    Looks like a JCM is firing when it's not supposed to. Have you recently installed any characters or other morph packs?
  • yes but if its one of the characters is there an easy way to locate it. Ive installed a bit of things and have no way of knowing which one is causing it
  • felisfelis Posts: 6,501
    Load a base G8M and bend the elbow.
    In parameters settings (the 3 horizontal bars) enable show hidden, and then for G8M click 'currently used'. Then you should see some JCMs. Try to list those.
  • thanks for your help.  I found the culprit.  the  Orc Horde g8.1 character  removed the morphs from data, arm bends fine now
  • FrinkkyFrinkky Posts: 388
    That is a band-aid solution. When you come to use the orc character, the JCM will be missing. You should file a ticket so Daz can get on to the PA to fix and publish an update.
