DAZ 4.15 Pro Crashes when I render Epic Sky dome Cloud Haven
in The Commons
I've used this skydome a lot in the past, and never had an issue, but all of the sudden, if I set the render options higher than the original sample size, it crashes the Iray render. I have 12 gig titan card, 128 Gig of onboad memory, and a 10 core i9 3.30GHZ CPU.
I don't even have anything else loaded except the skydome. If I change the render aspect ratio to 16:9 and up the sample setting to 1000 max samples, so the scene renders clearly, It crashes DAZ.
Not sure whats up, other skydomes work fine. Not happy that something that used to render fine, all of the sudden, does not.
JD
3840 x 2100 - 5M
2878 x 1626 - 95K
1480 x 1065 - 327K
