Gaibaldi hair suddenly causing Daz to crash.
I've been playing with the Garibaldi Hair for a while now, but suddenly it's started to cause Daz to crash when I get to the distribute screen.
I'm just trying for a fast and simple ringtray that jewelry vendors use to display cheap rings. I had been planning to use GH to give the inside of the box a velvet look....
It's just a simple cube with a small radius, made in hex. (tried first to use the bridge, then to save as a obj. and import it.) I've tried doing the same technique on some more advanced .objs and it worked fine, but for some reason this obj wont take hair... and no, it's not a second life primitive.
any thoughts?
EDIT: found the problem... Turns out I had a conflict between Shader Zones. Part of the area I was trying to paint was included in the area I had hid. I'll leave this up incase others have a similar issue.
